Tong choices or big pliers maybe?
Absinthe
I have a Jen-Ken Air Bath 16 (Vertical Knife Kiln) HT furnace on order.
I have no interest in becoming a blacksmith, forging my own billets etc.., so I have no gearing up for a forge and associated paraphernalia. It occurs to me that is the opposite of most people who start with a forge and add in a HT oven. So with a vertical furnace, a pin is put through a tang hole and the blade is balanced on a kiln furniture grate vertically with the blade/point hanging down into the main chamber.
I assume if I had forging capabilities, I would simply grab one of my myriad of tongs and use them. But that not being the case, I believe I need a set of tongs. It would seem they need to be able to grasp small blades and manipulate them in a quench tank without losing control. However, being neither a blacksmith nor a farrier I have no experience in what to ask for or buy.
Suggestions?
And, you don't find yourself having any problems grabbing smaller stock with the wolf jaw?
None at all. I make a small coupon about 2" x 3" every time I run up my oven to see how my blades are coming out. No issues grabbing that small of a piece.
Okay, I ordered a pair of V-bit tongs from Ken's Iron. Wish me luck :)
I have a pair of those as well. I can't pick up things quite as well with those, but they were much better for holding stock when I was trying to learn to forge and hammer steel!
I didn't mention Ken's Iron tongs because you mentioned having no desire for forging. Isn't all his tongs in kit form? I might have missed the completed tongs. Those Vee bit tongs are normally best for round stock rather than flat such as knife tangs.
Let us know how they turn out - Ken's got good stuff.
I discussed specifically what I was doing with Ken. These were his suggestion. Funny thing, I was thinking about retrieving the knife one way and he suggested a different way.
In the top loading kiln, there is a pin placed through the pivot of the blade. This pin lays on 2 parallel pieces of kiln furniture. I was assuming I would have to grasp the tiny little tab of the tang left over on one side of the pin. Now, on some folders, this can be perhaps 1/8". But Ken's suggestion is that I grasp the blade in the V-Groove, with the blade side in one groove, and the spine side in the other. So along the blade not across the blade. This way as deep as I stick the nose of the tongs between the furniture rails is the depth of the grip on the blade. Then I am not trying to grasp just a tiny little piece of blade.
He assured me that I should have no problem using a torch to do the minor offset of the tongs, and if I didn't want to I wouldn't even have to splay the V-groove, but could simply grind one in. But even that I should be able to handle. We will find out for sure. Soon enough.
Good deal. I'd not thought about grasping the blade that way. Ken's is for sure who I would have suggested had I realized you would be open to making them. Be sure to let us know how it works and show photos of finished tongs.
I forgot you were using a top loading kiln and hanging your blades. I'm sure Ken gave good advice.
I have a Paragon front loader and everything I make is stainless so all my blades are foil wrapped. very easy to grab with the tongs I posted.
I am open to just about anything. I just didn't think I "could"
I'm a fan of long needle nose for this sort of thing.
I just heat the jaws up and bend them to whatever shape I need. They work great. I even forge with them.
Don't forget to buy some high temp gloves. Here's a pair of Tillmans on Amazon. They make good welding gloves, but I heard they started making some of their stuff in China. Carolina makes similar gloves, but they're based in either NC or SC... pretty sure North Carolina.
I got some similar to these. They are great!
https://www.amazon.com/dp/B0922VZKQ...9Y2xpY2tSZWRpcmVjdCZkb05vdExvZ0NsaWNrPXRydWU=
I am hoping my welding gloves will work well enough to get started. If not I will upgrade. :)
