The way I find the most productive is : try and keep the same amount of hammer blows on each side , Constantly eyeball the sword by looking down the spine , That way you know where to hit to keep straight. In the Old Japanese tradition, there were 2 smiths and a master
He would point at blade with stick to show smiths where to hit blade . The Key to keeping them straight is , normalise frequently to relieve stress, Try and forge sword with same amount of hammer blows per side , I know its not possible to do this but, as close as you can get sure helps keep them straight. Forge blade as straight as you can and remember different types of quenching mediums make swords do funny things . If sword warps during quench , you can straighten with wooden mallet if done immediatly . When sword is finished , to check for even forging , Just lay sword on flat surface and look for warping . good luck ............... Bubba
If you are doing stock removal just keep it normalised and grind it evenly on both sides as much as possible . Make sure blade is evenly heated . No dark areas on blade.
