... Any BS-free, no nonsense approach is welcome. Thank you guys.
Well that is typically right up my alley. 52100 is not a very forgiving steel to HT, 1% carbon makes for a lot of extra carbide that you have to deal with so that it doesn’t give you problems, and to make it machinable it typically comes with that carbide very well spheroidized so that you need serious soaking or temperatures to get it free- these two considerations are in opposition to each other. It is little things like this that is the reason you see so many eclectic or unusual practices adopted by folks who heat treat this steel without equipment capable of meeting its demands.
What was your source for the 52100? Some is more spheroidized than others.
If you already have the razors ground to a close to finish dimension it could be a problem, since unlocking the needed carbon from the spheroidal carbide will require heating before you move onto hardening.
If the carbon is ready to go, in fine structures- pearlite, very fine spheroids etc… Heat to 1475F for 10 minutes and quench in any light oil. If available, Houghton, Parks AAA, McMaster-Carr, Brownells Tough Quench etc… are ideal oils for this steel, if not almost any vegetable oil will do for 52100 chrome levels.
For a straight razor I would go from 375F to 400F for two hours with the temper.
The nitrogen should not be necessary if you did everything correctly, if you see noticeable increases in hardness from cold treatment with a steel this simple, you overheated it and it is that simple. If all is done correctly you may still get around 6% retained austenite and squeezing more out of less than 6% should not be very perceptible on the Rockwell scale, I mean freezing a 66-67HRC blade doesn’t give you much more room for improvement.
Now for the down side- if your steel is heavily spheroidized the best way to free the carbon for hardening is to heat it to 1650F and let it air cool, and then proceed with the heat treatment, but if you are already shaped like a razor this can make a mess of it. In which case you may be left with some of the hokey pokey ("BS") dances that many do, in order to keep decarb and scaling down, but there will be increased distortion issues. I would rough out, profile or drill anything that has to be machined and then normalize before the final edge grind to avoid this.
With the carbon freed up, you can expect around a 66HRC as quenched, with it still locked in carbide you can expect around 63HRC as quenched.
