Ive never used a bushing before. What is the guidelines for using them ? How do you decide the thickness ? I guess you dont use washers with them ?
thanks
Dave
I make my bushings the thickness of the blade plus the thickness of both washers plus .002". The washers slide over the bushing. That way the liners close up tight against the ends of the bushing, leaving the washers and blade free to rotate. I don't use bushings in slipjoints, however. Just framelocks.Ive never used a bushing before. What is the guidelines for using them ? How do you decide the thickness ? I guess you dont use washers with them ?
thanks
Dave
