CPM 154 or ATS -34 ?
Tod Lowe
Hey guys,
I have been reading the best steel thread and I see CPM 154 being chose alot in the stainless category.
Its double the cost of ATS -34.
Is it really twice as good and what quality is the extra money going for?
And where can I buy some M4? :)
Thanks.
Cleaner steel and twice the lateral strength of ATS. It also grinds as easy and finishes out with a nicer finish.
Almost the same. CPM makes a powder metallurgy so it's purer, more prone to grind and to finish.
Powder metallurgy is preferable if the cost it's not so higher.
Hey guys,
Thanks.
No it's not twice as good but given the amount of steel used in an average hunting knife your only talking a few dollars which to many is worth it.
I thought ats-34 was almost the same as 154cm not cpm154?
I could be very wrong though(wouldnt be the first time):D
Ern, the chemistry on all three is dang near the same. The major difference is, CPM (Crucible particle metallurgy) is a "powdered" steel which makes it more uniform with smaller carbides. That's a good thing. Gives a boost to toughness, edge-holding, polishability, machineability, pretty much a step up across the board.
Here's Crucible's explanation of the CPM process. Pretty fascinating stuff if you ask me.
As Cliff said, I think the CPM version is always worth it, you're only talking a few dollars per blade. Plus it's a value-added thing... many knowledgeable buyers know this stuff and don't mind paying a bit more for the better steel.
Thanks for the replies guys.
The cost of most of the steels is really not bad but the shipping sucks.
If I could go down to the store and buy the steel it would be an easy choice.
Since im buying online I am getting a break on the shipping by buying in quantity.
Its 52.50 extra for a stick of cpm 154 cm multiply that by a few sticks it will add up.
The price difference is not much when just comparing by the inch.
I dont really do any mirror finishes so thats not a big advantage. Better edge holding is a plus though since I build user knives.
I will probably get one stick of it and try it when I order again. I may just get a sampler platter of steel next time I order.:D
Thanks again for the replies.:cool:
Hi Tod,
I used ATS-34 for years with great results, but the recent supplies of it is not as clean as it used to be, a real pain with surface pits! I switched to the cpm 154 and really like it for finishing & consistant heat treating. Plus it's made in the U.S. and that makes it more sell-able. I also like the cpms30v for an extremely tough knife that takes a great edge.
Sincerely,
Clint Sampson
Sampson Knifeworks
