Title pretty much sums it up.
I suspected the temperature on my evenheat was off by quite a few degrees.
I set up and calibrated my Auberins PID controller and K type thermocouple to exactly 32.0* in an ice slurry.
I drilled a hole in the centre of the front door of my heat treat oven and screwed the thermocouple into it.
I set the oven for 500* half hour soak and allowed it to come to temperature.
I watched the PID reading race to catch up to the oven temp. Around 500* the oven would hover up and down by 3-4 degrees. Reading 497-500* after about 15 minutes it settled on 499-500*
At this point the PID had settled for quite some time at 477* so roughly 23 degrees off.
So with that in mind... I'd love to hear some thoughts. I dont think the oven can be calibrated. I cant return it.
I will just run it and make the adjustments manually unless there is a reason not too.
