I tried a "link" belt on my KMG, and personally did not like it. In my case it caused a lot more vibration then a standard "V" belt. Now, to be fair, my KMG is setup a bit differently then most. I run a 3hp VFD setup, with the belt running through the benchtop to the motor, which is mounted under the bench similar to the way most belt drive table saws are setup. That means the belt is considerably longer then the average KMG.
