son of liberty
Ok I have a few questions for toughs of you using these. Im looking at building one but cant decide if I want to go with gas or electric heat. My plan is that if I go with gas ill build it much like a round forge on end with a PID controlled gas valve, pretty much the same if I go with electric only ill line it with soft brick and run the coil around the inside. As it stands now gas is winning but I just don't have enough experience to make a wise decision as to effectiveness.
Quench will be the same as always , oil tank with a manual burner to bring the heat up. From what I have been reading the greatest benefits of salt tanks are not in the low temp and if I can get away with using just one tank I would like that.
Any help would be appreciated greatly
