OkieCowboy
Hello all..new guy here...and new to knife making.
trying to figure out what I did so I don't repeat it..
ok at the point was going to epoxy the scales on and put in the pins... I had had them on several time to do some rough sanding etc.. had not seen or noticed a poroblem..
I lay everything out..get a few q-tips, raid the wifes make up stuff and get her acetone nail polish stuff since that was the one thing I forgot.. mix up the epoxy, put it on one scale put it in place..no problem..I make sure everything is nice and clean.. I slide the pins into place.. Ok now I flip it over put on some more epoxy and try and slip the scale down over the pins sticking up...it wont go..it's off on the center hole..no matter how i cuss and yell..it just aint gonna go..it's close...but...no
so..I am running out of time..the epoxy timer is on....i enlarge the center hole a tad..just enough for it to slip down over it ( don't ask me why I didn't pull pins or anything like that) now once the scale has cleared the end of the pin...its extra large hole has epoxy oozing out of it...I clean it up the best I can..and clamp it up...
now the clamps are off...and the center hole is awful..it's as if the drill bit wallered around in it a bit or something.. and it has epoxy in it...so there isn't gonna be much I can do i am afraid..
these scales have been interesting all along as it is...my Amish neighbors lost their grandpa last year and are in the process of tearing down his house..this house was built at least in the early 1900's and they wanted a knife built from the hardwood flooring from the house... and the key word there is HARD wood...
but my question is...
Is there a order for drilling the holes or pinning things up? or did I just have it out of whack... ( I know everything after that was pure panic mode on my part) if this does ever happen again,,I have heard of the superglue and sawdust thing...not sure how that all works..but can I fill the hole with epoxy and sawdust as well?
I do want to thank everyone in advance for any answers and help given...it's pretty awesome that a total new guy has a way to ask questions of makers of the skill levels I have seen here....
