Maybe it's because I'm new to knifemaking but I find myself needing stuff I don't have quite a lot. I am also not a rich man by any stretch of the imagination so I generally improvise or modify what I have. Does anyone else do this? Is there anything you improvised years ago that you still use?
For example, I only have a 1x42 belt grinder and I can't really access the drive wheel and the idler pulley is somewhere in the 3.5 inch diameter neighborhood so if I want to grind a radius smaller than that (and boy do I) I have to do it on my drill press with a drum in the chuck or a "flap mandrel" I made that I wrap sandpaper around. It takes longer but it works.
