garyschuler58@charter.net
New Member
Just wondering what is the preferred method of buying scales. already cut into 3/8" x 1-1/2" x 5-6" or by the block size pieces. Thanks
Do you think double-back tape is sticky enough to do this safely instead of gluing?I buy scales and blocks. I prefer 1/4 thick scales. If I buy 3/8 I usually have to thin them down. If I buy blocks and need to cut them into scales I use Fred's method. Works great!
I think with the tape you could possibly get some flexing that could cause the saw to bind. Fred’s method works so well I wouldn’t do it any other way. Why would you use tape? Save some time?Do you think double-back tape is sticky enough to do this safely instead of gluing?
Yeah you're probably right. Yes, was thinking to save time.I think with the tape you could possibly get some flexing that could cause the saw to bind. Fred’s method works so well I wouldn’t do it any other way. Why would you use tape? Save some time?
