On my NWG I 'crowned' the drive and idler wheels by hand using file, sandpaper, and calipers to be sure they were same dia each side. You want the surface to be crowned (not flat) so that the belt holds center when running. Some put a layer of tape on wheel slightly narrower that belt to get same effect but I had no luck with that. Idler wheel needs bearings as design suggests as well.
