All,
I have been making knives via the stock removal method since 2006. My pace is slow. I spend time on details, and I'm continuing to perfect my skills. I've spent my time making premium quality knives in hope of attending a show and possibly receiving some sort of award for something like "best new maker", etc. Yet, I've since sat on these completed knives and don't believe that I may qualify as a new maker anymore.
I use top end stainless steel bar stock such as ATS-34 and CPM S30-V.
I have the following knives available for purchase:
I am listing a number of knives in this posting which will be my "yearly quoata" per the site rules.
Sole Authorship Knives
Knife 0022: Drop Point Utility Hunter - $266 with sheath
Specifications:
Style: Drop point
Overall Length: 8-3/8 inches
Blade: 3-7/8 inch, Hand ground CPM S30V stainless steel, flat grind, 800 grit hand rubbed finish
Handle Material: "Popcorn" India Sambar Stag
Guard: 18% Nickel Silver
Fasteners: Brass Pins & Lanyard Tube
Knife 0021: Drop Point Utility Hunter - $235 with sheath
Specifications:
Style: Drop point
Overall Length: 8-1/4 inches
Blade: 3-3/4 inch, Hand ground CPM S30V stainless steel, flat grind, 800 grit hand rubbed finish
Handle Material: Desert Ironwood
Guard: 416 Stainless Steel
Fasteners: Stainless Steel
Knife 0019: Drop Point Utility Hunter - Available, $197.50 with Sheath
Specifications:
Style: Drop point
Overall Length: 8-1/16 inches
Blade: 3-1/2 inch, Hand ground ATS-34 stainless steel, flat grind, 800 grit hand rubbed finish
Handle Material: Hunter orange G-10
Knife 0018: Loveless Style Drop Point Hunter - Available, $202.50 w/sheath
Specifications:
Style: Drop point hunter
Overall Length: 8-1/8 inches
Blade: 3-5/8 inch, Hand ground ATS-34 stainless steel, flat grind, 400 grit hand rubbed finish
Guard: 18% nickel-silver, brass & nickel-silver guard spacers
Handle Material: Amboyna wood
Knife 0017: Loveless Style Drop Point Hunter - Available, $189.50 w/sheath
Specifications:
Blade: 3-11/16 inch, Hand ground CPM S30V stainless steel, flat grind, 400 grit hand rubbed finish
Guard: Naval Brass
Handle Material: Green Micarta, Red G-10 spacer
Knife 0016: Loveless Style Drop Point Hunter - Available, $255.00 w/sheath
Specifications:
Blade: 3-5/8 inch, Hand ground CPM S30V stainless steel, flat grind, 400 grit hand rubbed finish, Heat treated by Paul Bos
Guard: Nickel Silver
Handle Material: Snakewood
Knife 0015: Loveless Style Drop Point Hunter - Available, $215.00 w/sheath
Specifications:
Blade: 3-3/4 inch, Hand ground CPM S30V stainless steel, flat grind, 400 grit hand rubbed finish, Heat treated by Paul Bos
Guard: Nickel silver
Handle Material: Blue/Black G-10
Knife 0014: Small Bowie / Camp Knife - Available, $272.50 w/sheath
Specifications:
Style: Drop point
Overall Length: 10-7/8 inches
Blade: 5-1/2 inch, Hand ground CPM S30V stainless steel, flat grind, 400 grit hand rubbed finish, Heat treated by Paul Bos
Guard: Double guard, 416 Stainless Steel
Spacer Material: Brass, stainless steel, and black vulcanized fiber
Hangle Pin: Nickel silver
Knife 0010: Loveless Style Drop Point Hunter - Available, $235.00 w/sheath
Specifications:
Blade: 3-5/8 inch, Hand ground CPM S30V stainless steeel, flat grind
Handle Material: Snakewood Scales, Spacer: Layers of brass and black vulcanized fiber
Knife 0007: Hunter - Available, $187.50 w/sheath
Specifications:
Blade Material: 4 inch, Hand ground ATS-34 stainless steel
Finish: Hand rubbed 1000-grit
Handle Material: Black G10 fiberglass composite
Specifications:
Style: Drop point
Specifications:
Style: Drop point
Specifications:
Style: Drop point
Specifications:
Specifications:
Guard: Naval Brass
Specifications:
Specifications:
Specifications:
Style: Drop point
Specifications:
Specifications:
