scott.livesey
Dealer - Purveyor
hi, remember, it is all about SPEED AND FEED
go to eBay or Google and search for M35 or M42 drill bits; they are cobalt high speed steel. should be able to find Made In USA bits for a reasonable price. while there, also search for a #2 combined drill and countersink. We use these at the office for a centering drill. for most knife applications, the small drill tip should go most of the way thru, leaving you with a beveled pilot hole. Keep your speed down and use cutting oil. for O1(and it should work for other high carbon steel) 500-600 rpm should work well. you can tell you have the speed and feed right when instead of chips you have nice long curls, 3 or 4 inches long. when making a 1/4" hole, you should not be straining to pull the drill bit thru. be sure to clean your bit off between holes. I would also check that your drill table is level and the drill bit/chuck is square to the table.
the old sailor
the old sailor
