You could have a try at putting a peen block on your handle OP and doing a through tang. Just another little challenge for you as you seem to be a very quick learner so that would be another string to your bow.
Here you go OP.Thanks for the vote of confidence Von! I may just try that. I like that look too.
Would it still require a pin or is the peen sufficient to hold it all together.
Also, could you post a picture of that tool you made to clean out the drill hole for the hidden tang?
Also, a couple of close ups of the peened thru tang...……………….. THANKS!
i did not use a chisel, but a straight router bit to make a spot for the tangQuestion for you guys.
Have any of you ever did a hidden tang by re-sawing the handle and chiseling out the tang shape? I was thinking I might do one of these. I did one when I first started - it wasn't fancy and it didn't have a bolster on it. Here a picture of that one. In addition to the visable pin, I also installed a hidden pin for more integrity.
Bruce has some fine ones. These are mine I went to the mission and bought a couple of Old Hickory butcher knives. View attachment 64062Take your time and cut them down to the shape you want. For $2.00 each I came up with these. Make sure when you are cutting them down to leave enough for the teeth to be cut in! Then sharpen the teeth like you would the teeth on a handsaw!! I have used them for wood and inside of antler!! Use a long small bit and drill down into the wood or the antler. Go slow so you don't pop out, stop and measure the depth often! Bruce's are carbide if I remember right. So you don't have to sharpen them. Mine are easily sharpened with a V file if you need to. After all your not trying to cut a 2x4 in two, you are trying to cut out enough in the wood for your hidden tang. Always allow a bit more so you can get plenty of epoxy in the hole with the tang, unless you are going with a thru tang and then you want a tighter fit!!View attachment 64063
Innovation at it's finest. Great job on those.
