I cut out over 50 pieces of Hard Maple to send out to WSSI. The moisture % is around 10%, so I was going to let them sit for a few weeks and then check the %; should I use end grain sealer on the pieces or let them do it naturally?? The bigger blocks started to split, so I lost a good bit due to that.
Here are some pics!
I picked up a Harbor Freight 14" 4 speed bandsaw on sale/with coupon for $288. Got the Heavy duty hand crank tensioner, riser kit, Iturra 3" tension spring and Cool Blocks. Timber Wolf 105" blade and I have some regular tooth Olsons for the micarta pieces I make, and a Highland WoodWorker WoodSlicer blade for when they come back from stabilizing. Some vibration, but I haven't installed the adjustable belt yet. Went through the big sections of the wood w/o any problems!
Here are some pics!
