Awwww shucks, I've done this more times than I like to think - start a post, then hop over to another page to check something, come back and it's all gone requiring me to start all over! Looks like by now I'd do my writing in notepad, then do a copy 'n paste once I've got it where I'm really ready to post. OK, here goes again.
Anthony - NO!!! I am NOT an expert at etching. I do know a tad about electronics, and these etcher circuits are just simple little things. I built my etcher from spare parts laying around - built a couple of them in fact, one for a buddy and one for me.
Ya'll have the right idea, 3 or 5 seconds down, then up a second, then back down again. This does two things, one allows the stencil to cool a bit, and also to allow gas produced during the chemical reaction to escape. I'm not experienced enough to understand why a variable voltage etcher is required - with around 18-20 vdc and 17 volts or so AC seems to work just fine, and doesn't cause too much stencil heating. 12 vdc will certianly etch, just takes a bit longer. My first stencil was from Ernie, but the rest I've made using IMG stencil material. Patricia seems very knowledgeable and helpful.
A 24 vdc transformer (RS 173-1512 used) is a bit high. There you've got 24 vac, and with a full wave bridge and capacitor you've got over 30 vdc (open circuit) which is really a bit on the high side. How much the actual working voltage is depends on amount of voltage drop. That is measured with pad down.
In the image above you can see the "humps" the arrow tagged "Waveform without Capacitor" is point to. This shows how much ripple is from using only a diode bridge. By adding a filtering capacitor (220uF to 500uF) the final result is shown as much smoother. Which is best? Heck if I know, maybe there is no difference. Just thought I'd show what the capacitor is used for.
Fred, you said you have "
25.4 DC and 28.4 AC." h "IF" that had been 25.4 VAC and 28.4VDC I would have said that's about right. If you're using that radio shack 173-1512 transformer, you "should" be getting around 25 VAC, and with the full wave bridge I'd accept the 28 vdc, but wouldn't have been surprised if dc voltage had been a tad over 30 volts. Those are open circuit voltages?
Sure would be nice to have ya'll sitting here in shop - we'd help us all understand better.
Ken H>
