November-2012 Bubble Jig with a mystery damascus billet to grind on giveaway.
I have the 19 layers for the first weld cut and ready to tig weld. The billet is a mix of 1084 & 15n20.
The billet has been stick welded across its ends, the sides have been ground smooth, its ready to be TIG welded at 1 inch intervals down the sides.
This billet will be forge welded using hydrocarbon solvent, thats the reason for the extra welds down the sides. I don't want any movement during heating to welding temp.
The billet is 1 1/4" x 2" x 4 1/2".
The billet has been TIG welded on 1 inch centers, down both sides to keep it stable during heating.
The billet has been setting at 2250 for an hour; ready to press the layers.
The layers are welded, now to square the billet.
This is a picture of the carbon jacket that you get when you use hydrocarbon solvent to make the canister.
Looks like a good weld.
The weld was successful; all of the hydrocarbon solvent scale has been ground off the billet's surface; its time to draw.
The billet, after drawing, measures 1 1/2 x 7/16 x 17 1/2 inches long. Time to cut into five, 3 1/2 inch lengths and get ready to weld again.
Cohab, from Colorado, with his pick of 427 is the winner of the November 2012 Bubble Jig giveaway.
Congratulations Cohab, and thanks for playing Dogs. Watch for another giveaway in Jan. 2013.
