Von Gruff
This is the email I have sent to the seller of the stainless damascus I have done these two knives from
I tried to etch the two blades today with a very dissapointing result. Seeing as this was my first damascus I went to a good friend, John Worthington of Ripi Knives who I believe you know, to make sure I got it right and to learn the correct way to do the etching.
I had taken the blades to a 600 grit finish and after cleaning them with isopropyl alcahol they were suspended in the ferric chloride with checks every few minutes initially but when there was little change we left it for longer each time. after a half hour there was a visible change to the center core which was exposed by the bevel grind but nothing was showing on the rest of the blade. after an hour in the 4 to 1 ferric chloride we gave it a scrub with a tooth brush to remove any scale build-up and highlight the already darkened center core but still nothing on the remainder of the blade. After a full 2 hours etching we tried a mirror polish and a further 10 minutes etching with the same negative result except for deepening the etch on the center core and still nothing on the blade so is there some part of this process that needs to be done differently as I can not sell a knife with such a minimal and non effective etch when this is supposed to be a full pattern in ladder and rainbow for these two knives with the customer having seen the bars as they came from you with the pattern so very visible.
I would be pleased if anyone can shed any light on this problem
