gearhartironwerks
Hi,
Today I welded a 'W' pattern billet, turned 90 deg and drew it out. Upon etching to see the pattern, I have lighter colored weld lines between the layers of the final weld. The fit up was good, the mill scale was ground, and the weld is good as well. Technically, it's a good billet except for the visual lines between the layers of the final weld.
My question is how to eliminate those lines? Do I need to run the billet thru the surface grinder first? Your help greatly appreciated.
Thanks,
John
www.gearhartironwerks.com
Thanks,
John
