Tod Lowe
Im using 1080 steel.
I used the rockwell tester here at work and it reads im getting a hardness right at 56 hrc.
My process has been to temper for 2 hours at 400 degrees after the quench.
If I want to get a higher rockwell do I just cut back on the time in the temper oven? Our rockwell machine only goes up to 63 hrc so I couldnt check right out of the quench.
The 1095 steel I used checked at 58 rockwell and I only tempered it for 1.5 hours so im thinking I need to just cut back my temper time on the 1080?
