WIP -- 1st knife from scratch
Steven Janik
SUPERMOD & AWARDS BOSS
attachment.php
Here is the fixture I made to drill through the blade and scales at one time. I also use this to glue up spacer materials.
It also works great to clamp a knife will epoxy sets, but you must use waxed paper so knife doesn't stick to fixture.
These parts are from WOODCRAFT but should be available at any woodworking store.
Steve
seionage
Kept shaping more of the knife.
Bottom (sorry for the pic being so fuzzy)
Had to take a pic of all the shavings and dust under the knife.
seionage
Other side.
ready for pins.
I wanted to get as much work done as possible with the wood rasp, before I put the pins in.
seionage
pins were a really tight fit. In fact, I couldn't get the pin in all the way. I put it in as far as I could, and then I marked it,
where I would have enough left over.
seionage
Once I had it marked, I pulled the pin back out, and cut it with a hacksaw.
Then, I put it in the drill, and, while it was spinning, hit it with some 50 grit emery cloth.
seionage
Then, what I wanted to do, was notch the pin, so the epoxy would have some extra places to grab.
So, using my fancy sharpie, I marked 3 places.
Then, I put the pin back in the drill press, and, again while spinning,
I touched the pin with the hack saw. It gave me 3 nice groves.
seionage
moment of truth. No turning back now.
I mixed up the epoxy.
smeared a buch on the pins, and tapped them into place
One pine was nice and clean, another had a gob of epoxy. Oh well, nothing a file
won't fix when it's hard.
seionage
took the tape off the bolsters. (Nice job on the battle scars in the bolsters. *yuck*)
Now, I want to try and get the handle flush with the bolsters. Felt like it took hours. Sanded with 150 and 200, to try and flush them up.
this pick doesn't do it justice, but I'm trying to show the unevenness of the handle being higher than the bolster.
seionage
got some more 220 sanding to do. Quite the gap there.
Getting better
Almost there..
And...and...and I forgot to snap a pic of it being done. oops.
seionage
ok, then I started getting into finishing the handle.
I got involved with working it down;
400 to 1000 to 4000 to 6000 to 8000.
I totally forgot to take pictures between each step. I was really getting frustrated, because I would find a scrach that I forgot to take out, and then would have to back up a previous step (grit), and start that grit over. I don't think I have any skin left on my thumbs.
I'm kinda miffed at myself that I didn't take pics between grits.
I tried to take an angle shot, to show off the bolter finish.
seionage
I can't believe i'm done. I wish I could bring out more of a shine. If anyone has any ideas of what I can do, I'm all ears.
Some more shots of my baby!
